Super 55 Carb Info?
Biscuit
10-17-2003 07:17:54
Thanks for all the original input. Here is the findings after rinsing the carb with gas a few times and soaking with carb cleaner. She won't fire at all. Took off the air cleaner hose and lots of dark rust brown cleaner ran out, drained the carb bowl more rust color, rinsed it with gas till ran out clear. Found a little spring lying in the carb throat, part of the choke butterfly. Ordering parts today. What all do I need. Rebuild kit and replacement spring for sure what about float? Does all that gas/cleaner lying in the throat tell me anything else? Biggest question the carb is a Marv/Shrob TSX numbers on the tag are a 9, 55, 60 the 60 looks like it was followed by another that is worn off. Super 55 I think the early model. Anyone know what carb this is 603, 604, ...?
Thanks,
Biscuit
jake
10-20-2003 19:01:44
 Re: Super 55 Carb Info? in reply to Biscuit, 10-17-2003 07:17:54
When the carb is apart take the brass screw on the bottom out. Blow air through from both ends, a small particle in that orifice caused insufficent fuel and no start. Had to change the shutoff/filter bowl to cure.
Frank Dodson
10-17-2003 13:16:29
Call Maibach Tractor at 800-808-9934 and ask for Tom. He can give you the information you need and can supply you with parts.
Bric
10-17-2003 07:39:03
Biscuit
On mine(Super 55, 1955)its a Marvel Schebler TSX-603.
R. Marg
10-17-2003 08:13:21
 Re: Re: Super 55 Carb Info? in reply to Bric, 10-17-2003 07:39:03
my catalog lists only a TSX603 for that tractor
Biscuit
10-17-2003 09:01:41
 Re: Re: Re: Super 55 Carb Info? in reply to R. Marg, 10-17-2003 08:13:21
Thanks. I could only find a reference under replacement carbs and it listed the 55 Super 55 550 and some others together and a few carbs. Thanks again
J.Mash
11-09-2003 20:17:55
 Re: Re: Re: Re: Super 55 Carb Info? in reply to Biscuit, 10-17-2003 09:01:41
Call Rick Stair 330-264-9720 or ricksagriparts.com
R. Marg
10-17-2003 09:09:09
E- Mail me and I'll give you a phone number for a catolog that has a lot of parts for that tractor
