292 Chevy in a 77
Family Traditio
10-12-2003 08:26:56
I have heard of people doing this. Is there a lot of machine work or fabrication or is it pretty simple? Can someone please elaborate on this for me?
Ed
10-13-2003 14:26:12
 Re: 292 Chevy in a 77 in reply to Family Tradition, 10-12-2003 08:26:56
Wouldn't you have more horse power but less torque out of a stock automotive Straight 6? I understand the stroke is a lot longer on the original 6. I guess this would not be a problem if you don't intend to work it hard.
Family Tradition
10-15-2003 09:57:25
 Re: Re: 292 Chevy in a 77 in reply to Ed, 10-13-2003 14:26:12
this would be stictly for an outlaw puller..... .lots of rpm's!!!!1
TWV
10-12-2003 14:44:38
I have put a 300 6 Ford in an 88 with out to much trouble The rear of the block is a little to wide and the frame needs to be ground . I made my own bellhousing with the starter mount on the bottom. The flywheel may sound a little crude but it works. I machined the back of the 88 flywheel to fit into the recess on the 300 flywheel and bolted them together this allows you to use the pto hub and the oliver clutch. With belt drive governor this worked very well.Iwould guess a chevy motor would be very much the sameI have used mine for many years with much success. Alignment of engine is very critical Any other questions call me 330264 0851
