OC-3 Gen / Reg Charging Problems Update
John
10-11-2003 17:27:26
Hi Gang,
Many thanks to all who had pasted on their ideas to get our problem fixed.
To recap, we could not polarize our Generator after a rebuild. Output of Gen/Reg was a Positive 6 volts instead of the Negative 6 volt output we needed for our OC-3 (Pos Ground).
After checking everything, we finally tried putting on an old Generator from a parts tractor. It worked fine.
We opened both Generators to find that the rebuilt one had 2 wires switched inside. The wire from the Gen / Arm Term and the internal Field wires were switched on the 2 Brushes that are close together.
Again, thanks for the help!!
John
