770 with no power
peter
10-10-2003 17:42:44
seems to run fine under no load but under a little load seems to fall , i am going to check to see if dist is in correctly, has great compression , it only has 16 lbs of vaccum , i rebuilt carb and tuned it up what could it be i am stuck, going into 6th gearit will hardly go esp. if going up hill thanks pete in marquette p.s. when i got it it had 3 stuck valves
Ollie
10-11-2003 04:57:24
 Re: 770 with no power in reply to peter, 10-10-2003 17:42:44
Verify correct governor operation first. Stand next to the tractor, have someone else set the throttle a little above low speed, then release the clutch while in gear. The governor must kick the throttle rod; if not, the governor may be not hooked up, misadjusted, wear points dirty, lack of lubrication, etc.
Low idle vacuum is usually either:
1) retarded spark
2) wrong carburetor mixture adjustment
3) vacuum leak
The first two you can set by the book. To check for a vacuum leak, spray carburetor cleaner at the carb/manifold flange when the engine is at idle. Any change in engine speed or vacuum is a vacuum leak. If the intake manifold was off, do same test at each intake port/head junction.
Given that you had the carb apart, be certain that the float level is correct. Also make sure there is no restriction in the fuel line; disconnect it at the carb and you should have a solid, steady flow of gas. If not, there is either a restriction in the line/filter or the vent in the gas cap is plugged.
