High Rev Oliver
Jim
10-09-2003 22:33:39
I have an old 88 that has a problem or two.
When I give the tractor a little throttle the engine sometimes revs so hard I have to do a panic shutdown, other times it works fine.
What do I do to fix this?
WFE
10-10-2003 04:14:27
 Re: High Rev Oliver in reply to Jim, 10-09-2003 22:33:39
Sounds like the thrust bearing in the governor housing. Many times you'll find small balls from this ball bearing have worked their way to the oil pan, so if you change oil and find these little critters, that's what's wrong. I've also seen the throttle linkage to the governor (the main spring behind air cleaner) bind and catch which can cause this, or guys who have wired the spring for more speed.
