Ok, Willy, first thing is-this is the Oliver board, and Olivers don't have TA's. A TA (Torque Amplifier) is a power shifting device similar to the old Ford Model T planetary transmission. This device was designed to allow the tractor operator to downshift to another speed in the same gear without clutching, under power, when he hit a tough spot in tillage, or a hill in road work, or a heavy spot in PTO work, and then shift back up again, when he was through, or over, again without clutching, or loosing momentum. International Harvester tractors are the only ones with TA. Oliver used three different power shifting devices in their tractors: 1-Power Booster-a 2 speed 2-Hydra-Power Drive-a 2 speed 3-Over/Under Hydraul Shift-a 3 speed In the Oliver 995 GM Lugmatic a torque converter(not really a power shift) was used. The Case-o-Matic drive used in Case tractors was somewhat similar. There were many other power shifting devices used in tractors, almost every make had one, such as Minneapolis Moline's Ampli-Torque, in 2 and 3 speed versions, Allis Chalmers's Power Director, Ford's Dual Power, John Deere's Hi Lo etc... There were also FULL powershift transmissions such as John Deere's 8 speed, as used in the 4020, 3020, 2510, etc...simply called Power Shift, and Ford's 10 speed, called Selecto-Speed, used in the 4000, 5000, 6000, etc.. These transmissions allowed the operator to shift either up or down to any gear without clutching. I hope some of this helps. Others may elaborate further.
