Rear Wheel width Adjustments on 66/77/88
Dan
10-09-2003 07:45:46
I am buying a 66 and I need to move the rear wheels in closer so that I can fit it on my trailer. I know I have to loosen the straps on the axle hubs, but do they generally slide on the axles fairly easily? I have to travel pretty far to get the tractor, and I want to make sure I have everything I might need to do the job.
Jake
10-09-2003 08:41:32
 Re: Rear Wheel width Adjustments on 66/77/88 in reply to Dan, 10-09-2003 07:45:46
Loosening the U bolts will be the tough part, the wheel hub should slide when the keyway is up. If air is available an impact tool with a 1 1/4 socket will make the job easier. Also 3/4" power bar w/cheater pipe and a sledge should be included. Hope the tires are not loaded.
