oliver OC4 gas carb needle valve settings air/fu
D. Groff
10-08-2003 20:23:15
I have a 1957 OC4 gas crawler. I just cleaned out the carburator. The plugs always seem to fowl and get dark and dirty fairly quickly. What are the correct amout of turns for the air and fuel needle valve screws on this carb?
Thanks.
P.S. Everything is original on this crawler is original, can I use platinum plugs in it without too much trouble?
To:Mr. Grubb
10-09-2003 18:43:23
 Re: oliver OC4 gas carb needle valve settings ai in reply to D. Groff, 10-08-2003 20:23:15
What I have is an Oliver OC4 4 cylinder gas motor. My operators manual shows a plate picture that says Model-IXB-3. The model number for the crawler is: OC4-42-G.
I do not see any information on the carb itself. It has a screw with a spring just under one of the mounting bolts that connects it to the manifold. It also has a screw with a spring on the far right side of the carb and a screw with a spring for what looks like the idle speed stop.
Dave Grubb
10-10-2003 05:23:57
 Re: Re: oliver OC4 gas carb needle valve setting in reply to To:Mr. Grubb, 10-09-2003 18:43:23
Sounds like a Marvel-Schebler with the high altitude/kerosene carburetor.
The screw on the far right is the high speed adjustment.
Start the tractor and let it warm up. At full throttle turn the screw in until the engine begins to slow and then back out until the engine is runs smoothly.
For the low speed(under the manifold bolt) set the throttle at idle and adjust until the engine runs smoothly at 350 RPM.
Adjust the idle speed with the stop screw on the linkage.
Polk Crawler
10-10-2003 09:53:27
 Re: Re: Re: oliver OC4 gas carb needle valve set in reply to Dave Grubb, 10-10-2003 05:23:57
David:
Have a 4 cyl Herc gas engine, OC3, with M-S carb as described for the OC4. Small slotted screw about middle of top of the carb; to right a larger screw, no slot, serrated edge suggesting use of fingers to turn. Are your instructions for the OC4 MS carb valid for the carb on my OC3? Have not been able to locate specific setting info for my OC3. Thanks. PC
Dave Grubb
10-10-2003 14:40:24
 Re: Re: Re: Re: oliver OC4 gas carb needle valve in reply to Polk Crawler, 10-10-2003 09:53:27
Just a note---the high speed adjustment is only on the high altitude/kerosene carb. The standard carb only has the idle adjustment.
Jim N
10-11-2003 18:08:19
 Re: Re: Re: Re: Re: oliver OC4 gas carb needle v in reply to Dave Grubb, 10-10-2003 14:40:24
I too have an OC-4 gas with an IXB-3 Hercules.
My carb is a Marvel-Schebler like the one described. This is the first time I have heard anything about the carb being able to use anything but gas.
You've got me wondering now.
More information on this would be great! Thanks.
Dave Grubb
10-12-2003 06:29:48
 Re: Re: Re: Re: Re: Re: oliver OC4 gas carb need in reply to Jim N, 10-11-2003 18:08:19
Some of these were set up to run "low grade fuel"--aka kerosene.
This was pretty common on tractors at the time. We had Farmalls that were set up for it when I was a kid. I think a lot of it had to do with gas rationing during the WWII.
The Cletracs that were set up for it had a small gas tank under the front hood (in front of the radiator) for gasoline and the large tank became a kerosene tank. They would start on gas and once hot switched over to Kerosene (also called tractor fuel at the time).
Depending on the altitude things such as a radiator shutter, temp gage and different heads were added.
The carburetor that was used on the dual fuel engines seemed also to have been used for high altitude applications for gas only as well.
The HG we had when I was a kid was not set up for it, nor is the one I have now.
We did not burn it in our Farmalls after the war but my Dad said that when he did use it the power was much less.
For some reason it seemed Farmall did this most often and if you look at enough Hs and Ms you will see some with two fuel caps, one small and one large. The small one has a small tank under it and was the gas tank if you were running kerosene, if not it became a reserve gas tank--it would get you back to the barn if you ran out in the main tank ;)
Dave Grubb
10-10-2003 14:33:58
Should be the same since it is the same engine in both. The high speed screw tilts back toward the rear of the tractor at about 20 deg CW from vertical.
Dave Grubb
10-09-2003 16:59:47
What engine do you have? Number of cylinders and Carburetor would help.
If you have a four cylinder it should be an IX series Hercules with a Marvel-Schebler or Tillotson Carburetor.
To my knowledge neither one has an air adjustment. If you have two adjustment screws one is high speed and the other is low speed.
Let me know what you have and I can tell you how to set it up.
