Super 55 pto questions
Kelvin
10-07-2003 19:06:07
Just acquired 1954? Super 55. Pto engage lever is not hooked up. I was told something was warped inside. The pto spins when the engine is running.
But I can turn the shaft by hand with the engine off.
My question: Is the pto on the 55 supposed to turn all the time. In other words, is there a brake that's supposed to stop it when its disengaged?
If it does indeed normally turn all the time, in your opinion, would I get in trouble hooking up the pto clutch lever?
Super 55
10-07-2003 20:16:31
 Re: Super 55 pto questions in reply to Kelvin, 10-07-2003 19:06:07
The shaft will freee wheel when not engaged. It could be stopped by grabbing it, but don't do that. It isn't under a load. I wouldn't hook up the engage lever until I took off the cover and looked inside.
Jake
10-08-2003 08:22:43
 Re: Re: Super 55 pto questions in reply to Super 55, 10-07-2003 20:16:31
As 55 said check from underside through the inspection opening, something warped or broken could be the fork holding the release collar or the collar itself. These parts bent or broken would indicate a Z split will be required for repair and finding any other damage.
