S55 drawbar photo pls
Stu
10-07-2003 12:03:29
Can someone post a Super 55 draw bar assembly for me to model off of. Especially where/how it is attached. Thanks!
ShepFL - with link
10-07-2003 12:21:46
 Re: S55 drawbar photo pls in reply to Stu, 10-07-2003 12:03:29
Here is a link to an NOS swinging drawbar I got last yr. The square plate mounts to the bottom of the 550. Depending on the age of your rig it should work similarly. If not, give us a shout.
Kelvin
10-07-2003 19:00:43
 Re: Re: S55 drawbar photo pls in reply to ShepFL - with link, 10-07-2003 12:21:46
Shep, That swinging drawbar is similar but not identical to the with the Super 55 I just acquired. Mine is supposed to mount the bottom with a pin on each side, to brackets attached to the axle bolts. One side is missing, However. The top looks like it would pin in the lower 3rd link hole.
Could you tell me how long the actual drawbar is and how thick it is? I didn't get that along with the rest of the drawbar assembly.
ShepFL
10-08-2003 05:59:44
 Re: Re: Re: S55 drawbar photo pls in reply to Kelvin, 10-07-2003 19:00:43
Let me check tonight when I get home. I will post results.
Stu
10-07-2003 12:33:24
Nice, Thanks ShepFL
