Baler parts avaiability
Baler Informati
10-06-2003 00:30:22
I am considering purchasing an Oliver baler.
Are any parts impossible to find? What should I look for in an Oliver baler such as common wear areas etc...
Mostly need parts info though
Thanks
Leo
10-06-2003 04:37:53
 Re: Baler parts avaiability in reply to Baler Information, 10-06-2003 00:30:22
The 62T and 620 seem to be most common. I have gotten parts from Maibach and Obrien implement. I have heard that the knotters can cross with some of the older Hesston balers. It's a good idea to have a parts baler.
Check for the wearing of the knotters. It would be good if you could see some of the last bales baled and look at tightness of the knots. Another area to check is the slides and rails on the inside. Worn slides can really effect the baler performance. Otherwise, the other parts hold up and can be purchased.
They are excellent balers and when properly lubed, you have to look at the plunger to tell the baler is working! It is exceptionally quiet and can eat good size windrows. Pickup is a bit narrow so take that in consideration when raking!
