Need engine for 1650 diesel
William Mize
10-02-2003 06:29:22
Does anybody know of a good block or diesel engine for a 1650. I had done a valve job and put knew injectors (later model with pencil injectors) and then not too much later a rod broke and went through both sides of the block. It's not a pretty sight. Anyway I'm in search of an engine. This is a 1969 tractor.
Andrew M.
10-08-2003 17:55:44
 Re: Need engine for 1650 diesel in reply to William Mize, 10-02-2003 06:29:22
I wouldent put a cummins in it.. Reasons why becuase they brake crank shafts, thats a $4,000 bill and iw ould put a 3-53T detroit in it with 72 H.P with C55 Injectors you would have a machine thats cheep to run and also has a nice sound to it just keep a good muffeler on it and it will run quiet...
Shep Va
10-10-2003 13:41:32
 Re: Re: Need engine for 1650 diesel in reply to Andrew M., 10-08-2003 17:55:44
I have 4 Cummins 5.9L diesel engines running on the farm in Oliver tractors plus two more, one on a genset and one in a semi and none have never broken a crankshaft. And to be honest I have less trouble and get more reliabilty out of the Cummins engines around the farm than any of the Perkins, Cat, Moline, or Waukesha's that I have running. There is nothing wrong with a Detroit, I have serviced and run two of them as well, but putting one into a 1650 may be more of a challenge than you want. It can probably be done, but it will not fit as nicely.
Just my 2 cents.
Brad
10-02-2003 17:28:57
I' pretty sure we have a reconditioned block on the shelf. Need to know your casting numbers.
Maibach Tractor
1-800-808-9934
j meyer
10-02-2003 10:57:54
i honestly think you should replace the engine with a stock engine, instead of paying the big dollars for a cummins, and then you would have to be trimming out the tub and all. Shep has done it before is that interests you to do it.
Shep VA
10-02-2003 10:47:16
If you are using the tractor for work and are not concerned with keeping it origional I would suggest a repower to a Cummins engine. The Waukesha engines are good engines for their day, but they are 30 year old diesel technology. The reliability and power of a Cummins engine in an Oliver tractor is impressive to say the least.
I just finished a 1655 with a 5.9L Cummins engine this last spring and put the entire conversion on my website if you would like to check it out. It is a little pricy up front to put a Cummins in, but it will outlast and out preform the Waukesha for years to come.
Just a thought for you.....
Ollie
10-02-2003 09:57:49
Look down about 3 posts to "310..." It has some suggestions on how to locate a replacement engine.
Paul
10-02-2003 07:36:35
While your at it, you may want to consider replacing the waukesha engine with a cummins or a perkins engine- this sort of thing happens alot with that engine. How many hrs did it have?
