Cletrac on Rubber
Joe Giordano
10-02-2003 05:57:01
Ok heres one for you Cletrac pros, I am looking at a machine that appears to be a Cletrac crawler, has finals just like the crawler but has a steering wheel and wide front end, has dual rear wheels that are attached to the finals and appear to be factory, if not someone did a nice conversion. The machine says Cletrac on the radiator in front and down the sides and also on the 6 cylinder manifold, Has a peak hood and machine sits fairly high. It has a tag on the right side frame saying Cletrac GG. Anyone ever see anything like this, is it a factory setup or did someone do a nice conversion job. I am going back to look at it in a couple weeks and get some pictures.
J. Schwiebert
10-03-2003 18:18:15
 Re: Cletrac on Rubber in reply to Joe Giordano , 10-02-2003 05:57:01
A GG is a Cletrac. Very similar to the HG crawler. However it is not a 6 cylinder with a peak old type Cletrac radiator. Should have a four cylinder IKA or IXK Hercules engine. Have only seen one with a wide front.
RAB
10-02-2003 15:02:31
Came as a tricycle front as well. Was made by Avery when Cletrac stopped making them.
Regards, RAB
