Model 88 Electrical Diagram
Bob the Rookie
09-29-2003 13:19:30
Have a Model 88 (Gas) circa 1950's. Need electrical wiring diagrams that provide enough detail on the push starter, ignition/light switch, ammeter, coil and generator. The page I have from the Operator's Manual is not detailed enough. Would a appreciate a faxed copy (just let m eknow if someone has one). Got a big project this weekend since mice have eaten the wires!!!
#2 - I bought a new push starter but it does not have any markings to denote BATT, etc. How can I tell how to hook it up without shorting it out?
Thanks for the help...
Super 55
10-01-2003 19:34:17
 Re: Model 88 Electrical Diagram in reply to Bob the Rookie, 09-29-2003 13:19:30
third party image
See if this helps
bruce eaton
01-02-2005 01:34:32
 Re: Re: Model 88 Electrical Diagram in reply to Super 55, 10-01-2003 19:34:17
need wrng dgrm 4 super 55 dsl. 1957. Was hoping 88 might be similar all i got. THANX .
Bob the Rookie
10-02-2003 06:03:58
Thanks Super 55, on the diagram can you explain where the following wires go:
1. Red - to "B" terminal?
2. Green - to "L" terminal?
Was the original 88 a 6-volt system? The one I have is a 12-volt. Also, any pointers on determining how to wire the push starter switch to BAT and Starter since the posts are not marked?
Super 55
10-02-2003 20:44:12
 Re: Re: Re: Model 88 Electrical Diagram in reply to Bob the Rookie, 10-02-2003 06:03:58
I may be the last person to answer electrical problems, but from the looks of it the red wire goes to the battery terminal on the voltage regulator and the green is going to the "L" terminal on the regulator.
Why would it make any difference on the location of the wires on the push switch. Imagine it's a knife switch.. all you are doing is completing the circuit. Pushing on the switch just makes contact.
Ollie
09-30-2003 04:58:38
Factory wiring diagrams show wire colors and proper routing. They are not intended to show the specific connection at each unit. You might be able to find a book on basic automobile or tractor wiring. Tractors use automotive wiring techniques and electrical components.
As far as the mice... "One Bite" bar bait works miracles! Any feed store should have it.
