plow question
scott
09-28-2003 16:06:11
I have a nice 2-14 plow to pull with my s-55 but am not sure how to set it up. My question is where should the coulters be set at in relation to the plow points? I would also welcome any other advice and tips to proper plow setup and operation.
Don N
09-30-2003 10:42:21
 Re: plow question in reply to scott, 09-28-2003 16:06:11
The coulters should be set to cut about 1 inch to the land side of the plow point. Land side is the side opposite the furrow and plowed side. You need to set the tractor wheels and plow hitch point such that the tractor wheel runs in the furrow and the first bottom cuts the full 14 inch width. It is best if the plow can be hitched on the center line of the tractor, but this may not be possible and you may have to offset the hitch to get the plow bottoms in the correct relation to the furrow. You probably need the furrow wheel set as close as possible to the tractor for a 2-14 plow. Wheel position will influence hitch point.
When properly set, the plow should be level from side to side and front to rear while plowing. Both bottoms should be cutting the same depth and width. The plow should pull straight behind the tractor and the tail wheel should be running in the furrow, but not have much pressure on the furrow wall.
Hope this is some help. Properly setting up a plow takes practice and patience.
Good luck.
Don
Jake
09-29-2003 07:57:38
Setting up a trailer plow is very complicated. Starting right from the tractor tire tread width to the many trailer plow adjustments. My advice, get an old timer to come help you. I am still looking for an old timer to help me after many days trying to get it set perfect.
