oil pressure - 5 gear
Barry-KC
09-28-2003 10:21:35
Perhaps someone on the board can help answer my question. What is the factory spec regarding oil pressure on the Oliver/Hart-Parr 5 gear engine for the 70 series?
I recently purchased a '37 HP 70 with the 5 gear engine. It has all new "yellow-face" gauges. At idle, the oil pressure shows at about one-third. Above fast idle, the gauge peaks out.
I have been told that the yellow-faced gauges are designed for the later series of engines that operated at about 20 psi and that the 5 gear engines operate in the 35 to 40 psi range - therefore the gauge is maxed out.
I have a number of manuals on the 70 series, but could find no oil pressure numbers for the 5 gear.
Appreciate any inputs.
