Any 4-270's Working in Southern Illinois?
Merlin in Saint
09-25-2003 09:23:15
Just wondering: haven't seen a 4-270 in the field in a long time. I did some repairs on one for a farmer near Holmen, Wisconsin a few years ago, but I believe that he sold it last winter. Are there any 4-270's in the Greenville or Effingham areas, east of Saint Louis? I'd love to watch one work! I have been told that there were only about 300 or so of them built, and that they are rather rare. Hey, WFE; any info on production numbers? Thanks!
Merlin
Brad
09-25-2003 19:54:48
 Re: Any 4-270's Working in Southern Illinois? in reply to Merlin in Saint Louis, 09-25-2003 09:23:15
I've had way too much experience with a certain 4-270. We traded one in and it was a serious lemon. When we pulled the powershift drainplug we had to use a screwdriver to push the metal out of the way so the oil could run out. I would have had a rough time sleeping at night if I was the previous owner. The ONLY thing we haven't rebuilt is the engine. The mechanic that was working on it quit and didn't finish the job, so naturally I had a very large pile of parts to reassemble. We rebuilt the powershift completely and because of lack of maintenence we had to do some serious machinework on the housing (BIG bucks), the previous owners slammed it into park while it was still moving, so we gutted the rear end and machined the busted casting and made some new parts to work in its place. A couple of new gears in the transmission, along with some new shift forks and rails, a good used ring and pinion for the front diff, a used pinion for the rear diff, (you don't want to know what I had to do to find these), EVERY bearing and race was replaced,(NO exceptions) axles were dissasembled and the metal shavings were cleand out, junk planetary parts were replaced, new bearing, properly adjusted and reinstalled, PTO was completely rebuilt, hydraulics were completely dissasembled and cleaned, worn parts were replaced, new scavenge and lube pumps were installed for the powershift, the powershift control valve was completely rebuilt, and all the electrical was straightened out. I have driven it since I reassembled it and was in the process of fine tuning some pressure adjustments when we got busy again and I havent had time to finish it. This tractor is in pristine mechanical condition and very good cosmetic condition. It is for sale. I work at Maibach Tractor in Creston, Ohio
Doug
09-26-2003 10:03:52
 Re: Re: Any 4-270's Working in Southern Illinois? in reply to Brad, 09-25-2003 19:54:48
Brad,
I am running a 4-270 in northern Michigan and was wondering why the "Powershift filter bypass" light will be on for the first 20 minutes or so then go out and never see it again until the next day? Any help appreciated.
Doug
brad
09-26-2003 22:25:34
 Re: Re: Re: Any 4-270's Working in Southern Illino in reply to Doug, 09-26-2003 10:03:52
Doug, the first thing that comes to mind is that the filter is dirty and that the oil is bypassing until it warms up and becomes thin enough to pass through the filter, but I would assume that you would have changed the filter, if not then do so. I will think about this some more and get back to you.
Doug
09-29-2003 19:59:06
 Re: Re: Re: Re: Any 4-270's Working in Southern Il in reply to brad, 09-26-2003 22:25:34
Brad,
I have indeed changed oil and filter in it a couple of times but no change. Thanks for the information though.
Doug
09-25-2003 20:49:06
WOW!!! And I thought I had it bad just fixing the parking lock, the center bearings, and the control cables! How in the world does someone destroy a machine like that? It sounds like you have it well under control. I think that they are a marvelous tractor, PROVIDED that proper maintenance is done. I just can't see spending that kind of money on a machine, and then abusing it so. I hope that it sells soon, and at a good profit. Thanks for the info!
Merlin
brad
09-26-2003 22:30:01
 Re: Re: Re: Any 4-270's Working in Southern Illino in reply to Merlin in Saint Louis, 09-25-2003 20:49:06
I forgot to say that I know of four others running in this area. as for the profit, I will be suprised if we get trade in value of the tractor plus parts. It seems as if no one can appreciate the value of an older tractor that is mechanically flawless as this one.
