Oliver 70 Main Bearings
Johan
09-23-2003 09:39:18
Looking for main bearings to fit crankshaft ground to 56 mm diameter. Please tell me whom to ask. Prefer E-mail as I live in Finland.
EarlS.
09-24-2003 19:27:54
 Re: Oliver 70 Main Bearings in reply to Johan, 09-23-2003 09:39:18
Std shaft size on main journals is 2.249---2.250 Brgs are available in .010, .020,.030. Federal mogul part # is 568M for the main set. I think you have a problem because 56mm =2.205 .030 from shaft size is 2.219- 2.220. You can have your old brg shells rebabitt and cut to fit the crank.The preferable way is to repour to .060 under ,install in block and align bore the brgs to fit the crank. I hope this helps. Earl Seamands, Mahomet, Illinois
Jerry B
09-24-2003 05:46:26
These tractor were constructed using the "inches" method. We need to know the exact size in inches and thousandths there of.
