Oliver 1550 engine block
Scott Bartlett
09-21-2003 16:44:53
Looking for a engine block for a oliver 1550. I have been told a 770 has the same motor. I have a cracked water jacket and would prefer to repair if anybody has done this before and can recommend a way to do so. IF it's not worth it, anyone know were I could find a replacement..,.
Mr.T
09-22-2003 05:06:49
 Re: Oliver 1550 engine block in reply to Scott Bartlett, 09-21-2003 16:44:53
Scott,
There is a new stick rod for welding cast iron.
Look in google "block repair".
Worked great on a exhaust manifold.
Bob
09-21-2003 18:54:58
I have a good block here for your 1550 E-mail me if your interested
Ollie
09-21-2003 17:13:47
The chances of a successful long-term repair are slim. Depends on exact characteristics of the crack.
If you really want to keep the tractor, I suggest you find another 1550 that has a sound engine but is for sale real cheap due a bad transmisson/final drive or some other serious problem. This way you will not only have a decent replacement engine you can swap in as a whole but lots of spare parts that fit your tractor.
If you don't want to keep it for the long haul, post back and I'll give you a phone number or two of places that buy dead tractors and part them out.
Scott B
09-21-2003 17:22:26
 Re: Re: Oliver 1550 engine block in reply to Ollie, 09-21-2003 17:13:47
The Tractor was purchase new by my dad and I'm helping him get it back up and running. If you have a source for part tractors, either a 1550 of 770 engine will work.
Thanks
scott
770
09-21-2003 16:55:52
I have a farmall "A" that I patched the engine block using JB weld. Keep in mind I rarely use the Tractor for heavy work. Also the "A" has no pressure in the system. No water pump either. By the way, I have 770's and they have 1550 pistons in them. Just a thaught?????
Scott B
09-21-2003 17:03:23
 Re: Re: Oliver 1550 engine block in reply to 770, 09-21-2003 16:55:52
Thanks for the response. I believe the D 1550 has pressure in the system. not sure if JB weld will hold under pressure...
J. Schwiebert
09-27-2003 16:04:20
 Re: Re: Re: Oliver 1550 engine block in reply to Scott B, 09-21-2003 17:03:23
If the crack is external I would pin it. Much more reliable than stick welding.
