Pulling motors
jag
09-18-2003 19:52:00
can any one tell how to produce 90-120 hp out of a 88 oliver?
brad
09-21-2003 15:39:20
 Re: Pulling motors in reply to jag, 09-18-2003 19:52:00
it all depends on the rpm range you want to run and how much you want to spend. if you want a stock rpm motor go with 4.0 bore and offset grind a 99 for chrystler rods and this produces 4.5 stroke creating 340 cid and a excellent rod/stroke ratio. with a good camshaft, head, intake, and carb this will put you right where you want to be without boring the block. or you could go 4.375 bore and stock stroke creating 361 cid and a real good rod/stroke ratio. it all depends on what you want to spend and what your future plans are. i sell parts for these and also build engines. call me at 330-939-0124 leave a message i will call asap
Chad Mathison
09-19-2003 13:20:09
Open your wallet!!! HP comes pretty easy with the cash! Chad
