oliver 1650 wheels
William
09-15-2003 17:39:09
My brother and I just purchased five tractors and two of them are oliver 1650's. My question is the rear wheels on both have the curved square tubing on the wheel at the attaching points and I was curious if those can be taken off or if they need to stay cause I want to widen the wheels for bigger tires and they really aren't that good looking to begin with. Also will a hub and wheel assembly off of a 1855 fit a 1650 bolt pattern.
Big Jim
09-17-2003 09:53:08
 Re: oliver 1650 wheels in reply to William, 09-15-2003 17:39:09
I have an Oliver 1655 with those "spin out" type of rims. I agree, they are kind of ugly. I have never used the spin out feature. I think the idea is that you loosen the clamp bolts on the square tubing and then move the tractor. The centrifugal force makes the wheels move out or in depending on where you have them set now. I know of no reason why I would want to change the rear tread width. Maybe there's some special applications where someone might do that.
evielboweviel
09-17-2003 18:15:35
 Re: Re: oliver 1650 wheels in reply to Big Jim, 09-17-2003 09:53:08
move wheels out for 4 bottom plow, to cultivate corn in 40" rows, for a mounted picker, list goes on. I feel that an Oliver will adjust by sliding on axle easy enough not to need spin out wheels.
brad
09-16-2003 05:14:08
From what i understand you have a set of powershift wheels yes all of the oliver 9 bolt patterns will interchange any Questions call me at 1800-808-9934 ask for brad
