Motor kit for 88 Orchard Diesel
Isaac
09-11-2003 10:29:55
I have a 1953 88 Orchard Diesel and needs motor overhauled. It's geared to high and needs a lot more power for the speed it runs. Any help appreciated. Thanks.
Greenjunk
09-14-2003 19:47:15
 Re: Motor kit for 88 Orchard Diesel in reply to Isaac, 09-11-2003 10:29:55
If you are he11 bent on greatly!! increasing the HP, then buy you a turbo kit. Yes, it does come with a large hole in the block at no extra cost!
J. Schwiebert
09-12-2003 08:49:19
You asked an interesting question. First you did not say if you had it on a dyno and how much power it has now. Next in your mind how much horse power are you looking for? Next thing a kit may help you but what about a good diesel tune up?
Isaac
09-12-2003 16:43:38
 Re: Re: Motor kit for 88 Orchard Diesel in reply to J. Schwiebert, 09-12-2003 08:49:19
I've had the tractor on my dyno it puts out about 32 hp at pto speed and about 40 lugging it down. Do you have any other tips.
J. Schwiebert
09-12-2003 18:07:40
 Re: Re: Re: Motor kit for 88 Orchard Diesel in reply to Isaac, 09-12-2003 16:43:38
Don't know Need to ask a million questions so to speak. Find me an email me your address on the Hart-Parr web site.
sos puller
09-11-2003 19:30:15
take a row crop rear end and trade your axle housingsand put your orchard tub onto the rearend it will slow you down to aprox 2.85 mph or even as much as 2mph with a 9-51 ring anpinion hope this helps
Isaac
09-11-2003 20:46:21
 Re: Re: Motor kit for 88 Orchard Diesel in reply to sos puller, 09-11-2003 19:30:15
I don't know if i'm up for that much work but thanks for the info it might help me later
Isaac
09-11-2003 17:47:38
Thanks. But I knew that Korves had engine kits at fair prices, but I'm looking for a kit to greatly incease horsepower.
RAB
09-12-2003 08:26:25
 Re: Re: Motor kit for 88 Orchard Diesel in reply to Isaac, 09-11-2003 17:47:38
Then fit a turbo!!!
Regards, RAB
Chuck
09-12-2003 17:00:39
 Re: Re: Re: Motor kit for 88 Orchard Diesel in reply to RAB, 09-12-2003 08:26:25
A turbo alone will not result in a large horsepower gain. It will tend to improve efficiency,but you would also need more fuel to boost horsepower that dramatically. My 2 cents worth.
Ollie
09-12-2003 17:13:57
 Re: Re: Re: Re: Motor kit for 88 Orchard Diesel in reply to Chuck, 09-12-2003 17:00:39
When you add any supercharger, you add more air per cylinder charge so you must also add more fuel. 50% hp gains are common on diesels.
Chuck
09-13-2003 08:39:38
 Re: Re: Re: Re: Re: Motor kit for 88 Orchard Diese in reply to Ollie, 09-12-2003 17:13:57
Go back and actually read my post.
Ollie
09-13-2003 09:06:40
 Re: Re: Re: Re: Re: Re: Motor kit for 88 Orchard D in reply to Chuck, 09-13-2003 08:39:38
No thanks, I already did.
