oliver generator wiring
dale carter
09-10-2003 17:46:31
i am trying to wire a gen.and regulator on a 1951 rocrop 77 gas tractor. do run a hot wire from the key switch to the B post on top of the reg.and then a wire from the f post to the field post on the gen.and a wire from the A post on the bottom of the reg. to the A post on the gen.will this complete the charging surcut. this is a 12v system.do i have to have a recester in the wire from the key switch to the reg.
Mark
09-10-2003 19:09:23
 Re: oliver generator wiring in reply to dale carter, 09-10-2003 17:46:31
Dale, The red wire in your harness goes from the amp meter to the Batt on the regulator. The green wire in your harness goes from the L terminal on the regulator to the ignition switch. You will also need a wire from the F terminal on the regulator to the F terminal on the generator. Do the same with the A terminals. When using a 12v regulator you will not need any resistors.
Mike (WA)
09-11-2003 08:13:08
 Re: Re: oliver generator wiring in reply to Mark, 09-10-2003 19:09:23
I may be mistaken, but I think the resistor question depends on the coil you have- some coils have internal resistor, but others need an external. That being said, someone smarter than me please jump in with the specifics.
Mark
09-11-2003 09:06:38
 Re: Re: Re: oliver generator wiring in reply to Mike (WA), 09-11-2003 08:13:08
Yes the resistor is used in the circut to the coil. Some coils used internal resistors and others use external. You do not use a resistor in the charging circut.
