differences in 77 and 88? thanks
eric
09-04-2003 15:46:58
sorry i am sure this has been done before, but if an 88 was 10 yards to my right and a 77 10 yards to my left, what differences would i notice? i have a 77 that apparently has a super 77 front. (by this i mean every thing in front of the tranny) the seat is a tsc model, wheels from a 770, etc etc. anyway the tractor was saved from the scrap man but is diving me nuts to make original again. when i do the engine could i just slide in an 88 motor or an diesel (tractor is now gas) and apply the 88 decals? would it look right to all but the oliver expert? as always thanks for your thoughts. eric
Rick
09-05-2003 05:45:11
 Re: differences in 77 and 88? thanks in reply to eric, 09-04-2003 15:46:58
Eric I have a 77 parts tractor if this would hyelp you out. $300.00 for whats left.
Loren
09-05-2003 20:16:35
 Re: Re: differences in 77 and 88? thanks in reply to Rick, 09-05-2003 05:45:11
Row Crop or Standard? Where?
Rick
09-06-2003 10:31:06
 Re: Re: Re: differences in 77 and 88? thanks in reply to Loren, 09-05-2003 20:16:35
I thought it was row crop, located southeast Iowa
J. Schwiebert
09-04-2003 16:55:14
Sometime compare an 88 and a 77 up close. There is a lot of difference. Do you have a tractor serial number? How about a casting number for the engine which is located behind the starter. Except for the imput shaft , the transmissions and final drives are different
eric
09-04-2003 18:15:19
 Re: Re: differences in 77 and 88? thanks in reply to J. Schwiebert, 09-04-2003 16:55:14
thanks j schwiebert, the serial # says its a 1950 model according to this site. no clue on the engine number , ill check. how will i know if it matches the serial? will it be the same? i called ollie schafer last night and he told me the front was likely update to a super 77 to accept more modern implements. even the brakes are different on this tractor. one a wider band than the other. i want to pull this tractor in a stock/restored class our local club has, but its getting hard to figure out this jigsaw tractor i got. it was free and i love having it to work on, just trying to deside which way to go.
J.Schwiebert
09-04-2003 18:37:00
 Re: Re: Re: differences in 77 and 88? thanks in reply to eric, 09-04-2003 18:15:19
I mentioned checking the engine casting number. The engine serial number is on the other side on the flat flange next to the back of the engine. They can be a little tough to read and in no way is it similar to the serial number. On your tag you should have like C77D (example) after the serial number which will tell yopu if you have a standard or slow speed ring & pinon. I would pull it as a 1950 77. Do they check you on the dyno. Around here the stock out of the field class goes by weight and horsepower.
eric
09-05-2003 04:54:13
 Re: Re: Re: Re: differences in 77 and 88? thanks in reply to J.Schwiebert, 09-04-2003 18:37:00
mine does say c77d. which ring and pinon is that?
Jerry B
09-05-2003 06:20:19
 Re: Re: Re: Re: Re: differences in 77 and 88? than in reply to eric, 09-05-2003 04:54:13
eric,
the easist way to determine wheather an Oliver is a 77 or an 88 is to look at the bottom of the grill. The 77 is even all the way to the bottom. The 88 grill has an inset at the last 1 1/2 inches at the bottom.
