injection pump timing
Dave in KS
09-03-2003 21:22:02
I just had a Roosa master injection pump rebuilt on a 550D and been reading past posts on getting the pump timing correct with the engine. How do I know when the #1 cylinder is on the compression stroke? Thanks for help.
RAB
09-07-2003 13:35:08
 Re: injection pump timing in reply to Dave in KS, 09-03-2003 21:22:02
Both valves will be closed.
Just watch the valve operation.
Induction stroke - inlet valve will be lifted
Compression stroke - both valves closed
Power stroke - both valves closed
Exhaust stroke - exhaust valve open.
Of course there will be some overlap and timing will be a few degrees around bottom and top dead centres, but it is so easy once you have done it, you will wonder why you ever asked!
Regards, RAB
J. Schwiebert
09-04-2003 12:46:08
Several ways to do this. Did you send the fuel injections nozzles to the shop? If you did that,before you put them back in put your thumb over the opening for number one and feel the compression build. if not take the energy cell cap and plug out of number one cylinder. You need to put your thumb over the hole you just created to see when it is comming up on compression. Also make sure you clean the timing tape on the flywheel so you can see the timing marks.More questions, send me an e-mail
