Need model info "BIG OLIVER"
cary
03-30-1998 20:43:32
while looking at a jd sicle bar mower today I found a huge oliver tractor. tractor could probally be bought but owners are fairly educated and probally know the value of the tractor better than i would. tractor was in the dark but large diesel, top sheetmetal missing but rails had hydromatic drive on it and the grill was large cast iron, wide front, my grandfather estimated it was 80 to 100 hp range by the size of the implements they have. If I go back where is the model # or s.n plate.
Larry H
03-31-1998 16:23:06
 Re: need model info "BIG OLIVER" in reply to cary, 03-30-1998 20:43:32
on a late model Oliver it would be on the dash down by the gear shift
: while looking at a jd sicle bar mower today I found a huge oliver tractor. tractor could probally be bought but owners are fairly educated and probally know the value of the tractor better than i would. tractor was in the dark but large diesel, top sheetmetal missing but rails had hydromatic drive on it and the grill was large cast iron, wide front, my grandfather estimated it was 80 to 100 hp range by the size of the implements they have. If I go back where is the model # or s.n plate.
john h
04-12-1998 17:37:46
 Re: Re: need model info "BIG OLIVER" in reply to Larry H , 03-31-1998 16:23:06
Interested in BIG OLIVER, Hydra/power drive indicates 1960's model. More info.
: on a late model Oliver it would be on the dash down by the gear shift
: : while looking at a jd sicle bar mower today I found a huge oliver tractor. tractor could probally be bought but owners are fairly educated and probally know the value of the tractor better than i would. tractor was in the dark but large diesel, top sheetmetal missing but rails had hydromatic drive on it and the grill was large cast iron, wide front, my grandfather estimated it was 80 to 100 hp range by the size of the implements they have. If I go back where is the model # or s.n plate.
john h
04-12-1998 17:36:35
