Adding a belt Pulley to 66/77/88
Dan
09-03-2003 13:24:32
I was wondering, can you easily add a belt pulley setup to a 66 that didnt come with one? Are the belt pulley drives from the 77/88's the same unit? What would need to be done to do it?
dean
09-03-2003 18:21:06
 Re: Adding a belt Pulley to 66/77/88 in reply to Dan, 09-03-2003 13:24:32
dan i would be interested in the covers that you remove for the transmission shaft bearings if you decide to install a belt pully assy..thanks
J. Schwiebert
09-03-2003 17:23:26
O. K. the pulley drive for a 66 is different than a 77 or 88. The 77 and 88 are the same. A pulley gear box off a 66, Super 66 or 660 will work. The pulley itself is the same as a 77 or 88 since all three engines run the same RPM. Supers and 660's use a smaller diameter pulley. Easy to do on a 66.
