thanks ollie ajax need more info
larry h
09-02-2003 17:07:21
is there a chance the shims were too thick and heated crank also every rod has the no sanded off but the nos. are on the caps it does not seem to have been low on oil and original owner seems honest weould you still line bore we are already going to to put in cam bearings etc thanks for info it is the only way we can learn we are restoring the 1850lp to use at plow days
J. Schwiebert
09-02-2003 19:24:04
 Re: thanks ollie ajax need more info in reply to larry h , 09-02-2003 17:07:21
Let us back up one step on that crank. First of all with out an engine number or a serial number you may have a replacement crank to start with. Ollie is correct with the straight edge, but take it to a shop that has a dial bore gauge to check the mains. Why do you think they changed them material wise in later engines Also wet mag the crank. Wet mag(black light crack detection) is better than magnaflux. Magnaflux is a little weak for crack detection on a crank. Also there are two types of cracks on cranks, the one will kill you the other one most likely will not bother. Also for fun and adventure, rockwell the crank and see if the harness is gone. It is interesting the crank got hot but most likely it was because of low oil level. You are a 1000 times better off taking these extra steps now and then not having it fail while you are out plowing. Definately get the bores on the rods checked. Do I recall it spun a rod? 99.9% chance that bore on that rod will be out of spec and you will spin it one more time if you do not correct the problem.
Ollie
09-02-2003 17:42:58
Yes, the machinist will lay a long steel straightedge along the main bores. He will then tell you if needs needs to bore the mains. As long as new bearings are going in, he should at least hone them.
If you feel the crank was overheated, you can have him index the crank and check it for straight. If you are looking at amber or darker colored burns on the crank, you should have him magnflux it to reveal any cracks.
ajax implement
09-02-2003 17:32:38
First of all do you have the engine out of the frame. Second on the rod numbers, are you talking Waukesha numbers or did someone number the rods from 1 to 6. Waukesha does not do that. Waukesha numbers the caps and rods. These numbers may be from from 1 to 99. Have you miked the crank? Have you put a rod on the crank with and without the shim and checked the clearance with plastigauge? I would definately take the rods and block and get those bores all checked. Get the rods reconditioned and throw the shims away! Also put the one piece pin bushing in even though it is a gas job. Just asking, do your rod bolts have washers under the heads? More information needed post on the Oliver/Hart par web site. I hope you do have dimensions. Any good machine shop will have the dimensions for the rods and mains as they are in both the F-M and Clevite bearing cataloags. Remember we are playing with 10ths of thousands here. Where and when is your plow day?
