info on super77 brakes please.
eric
09-02-2003 10:58:24
i have a super 77 that sat for about 6 years before i got it. i was always told that super 77s had disk brakes but i would discribe mine as a band type. is this right? the left cover measures about 2 1/2 inches out from the frame, while the right cover sticks out about 2 inches but has a few spacers or shims. which is correct? the piece that twists to tighten the bands when the peddle is pressed moves back in forth on the left but not the right. is it supposed to move in any direction besides twist? as always thanks for your time.
J.Schwiebert
09-02-2003 14:45:16
 Re: info on super77 brakes please. in reply to eric, 09-02-2003 10:58:24
If you have band brakes, which is what you are describing, you do not have a Super 77 or even a late 77. If I would not have my books put away I could tell you the serial number where they changed, but it is close to the fall of 1952. You also describe what we called a style 3 band brake. In that case the serial number for your your tractor is located on the upper right side of the transmission case. It may be on the dash, but if it is it is the old style serial number set ups. I have seen a very few of them
