gasoline valves
Barry-KC
09-02-2003 10:19:28
Old cars and many tractors had brass shut-off valves for the gasoline line and they were often in addition to any sediment-bowl (bulb) shut offs.
They varied from one-way to three-way and had some real substance to them. On one of my Oliver 70's the shut-off even has a thumb lever that makes it so much easier to use.
The only modern types I can find are flimsy, are hard to operate and use a simple nail like shank for the thumbscrew.
My question is: Is there any company out there that makes the good old time heavy brass gasoline shut off valves?
Appreciate your help.
Delbert
09-03-2003 19:30:46
 Re: gasoline valves in reply to Barry-KC, 09-02-2003 10:19:28
The three way valve you refer to is likely one from a kerosene or fuel oil burning tractor so the engine could be started on gasoline and switched to fuel oil when hot, also when turned off the engine would empty the carburator so it could fill with gasoline when started next time, otherwise the fuel would need to be drained. Delbert
Ollie
09-02-2003 11:22:30
I use the standard ball valves available at any hardware store. They last forever, don't leak a drop, and have large handles that allow easy on/off even while wearing gloves.
Barry-KC
09-02-2003 15:23:19
 Re: Re: gasoline valves in reply to Ollie, 09-02-2003 11:22:30
Thanks Ollie
I feel like such a dummy!! I had checked at auto supply and large builders-supply type joints - even a few tractor dealers, but not the regular hardware stores.
I will check on your lead tomorrow
Thanks again,
Barry
