ollie or engine pro i need help
larry h
09-01-2003 17:23:46
i have worked on olivers for 20 years but we tore down a 1850lp today and the crank does not have a dowel for the flywheel to lineup by the casting no is 221411 what have i got also the tractor has rod bearings dated 1982 but under each one is a thin shim was this to keep down a knock we bought tractor and knew it had a spun rod crank appears to have been run hot probably because the engibe was out of balance any help appreciated
Ollie
09-02-2003 04:54:38
 Re: ollie or engine pro i need help in reply to larry h , 09-01-2003 17:23:46
Ajax gave you a great answer. The engine was almost certainly run with the oil level low, maybe many times. You'll want to also check the cam bearings, piston skirts, and rings for signs of overheating.
Be sure the machine shop has the specs from the manual. Let's hope they can save the crank. Be sure to tell them the engine was out of balance; you'll want them to balance the entire assembly which the last step after all the other machine work is done.
ajax implement
09-02-2003 03:59:46
Later engines and or replacement crankshaftsdo not have dowels. I may still have a service bulletin that states this. What is the Clevite or Waukesha number on the back of the rod bearings? There was a change in these too. The shims are not original equipment. Remember oil cools, it may have been run too low on oil. May sure you have the rods reconditioned and the block taken to a good shop and the alignment and diameter of the main bearing bores checked
