oliver 50
WAYNE
08-23-2003 08:51:15
I have a oliver 50 tractor and would like to know more about it how many were made and what it is worth
J. Schwiebert
09-02-2003 15:05:13
 Re: oliver 50 in reply to WAYNE, 08-23-2003 08:51:15
Wayne: Please send me a phone number as I can not get an e-mail to go back to you Thanks.
J. Schwiebert
08-27-2003 17:01:30
Please send me another e-mail. I can not get one to go to you.
Wayne
08-25-2003 21:25:43
After talking to others I found this tractor to be an Oliver 500 instead of an Oliver 50. I appreciate all the follow-ups. Can you tell me about the Oliver 500? How many are out there? Possible value? It is in fair condition.
Wayne
Terry
08-25-2003 17:55:43
Wayne-I also have an Oliver 50. Seems to be a very unusual tractor. Do you have an industrial or an agricultural model? Most of the industrial models I have seen were sold as power units for equipment manufactured by others. I have an ag unit, which is basically an Oliver 90. Mine has a rice field equipment. It appears most ag models were built for export. The 50 uses the same series of serial numbers, both for the ag or the industrial models. It is unclear how many were made, as the serial numbers are not separated from the 90 & 99s. Would be interested in talking to you. Terry.
Delbert
08-25-2003 12:26:24
Thge Oliver 50 is an industrial model. In Wendels book there are two pictures of a 50. It is the version of the 90 tractor built in the 1936 and 1937 era. The book states the 28-44 Industrial became the 99. Hope this helps. I have seen verry few Oliver industrial models of this era, although I have a Model 35 which is the industrial farm {looks like an 80 with some variations} version of the model 80. The fully industrias model has a different operators area, heavier cast wheels with wheel brakes in the wheel, I believe it has different gear speeds. I have seen only one 35 like mine and one fully industrial model 35, I have seen no 50 models. As to value a wild guess might catch it. It is definitely a keeper as not many were produced. Delbert
Trevor
08-25-2003 06:50:58
I think you have the wrong model #.
There are 55, 550, 500, 1250 and many other larger tractors with xx50 but I have never heard of an Oliver 50. There was Oliver 60, 70 and 80 but 60 was as small as it went being only about 18 Hp.
John Deere had a 50 and Cockshutt had a 50. Check you make and model again and if you are not sure post a picture here or on the "Help Identify" picture board. Even give a good desciption and we might be able to guess.
Frank Dodson
08-24-2003 16:15:44
Maybe some one can shed some light on your question but I have never heard of a model 50 Oliver.
