White tractors
Pete in Ks
08-21-2003 06:55:38
When exactly did the white tractors change the paint scheme from a striped side cowl to the red stripe. I see tractors for sale that are designated as the same year but have different painted side cowls.
Pete in Ks
08-22-2003 08:44:07
 Re: White tractors in reply to Pete in Ks, 08-21-2003 06:55:38
Thanks guys. The tractor in question is stated as a 1977 model but has a red stripe WFE. I will check the serial no.'s to see for sure.
WFE
08-21-2003 09:06:00
1981. In late 1980, White had secured new financing through parent company TIC, or Texas Investments Corp. and for 1981 model year introduced what is unofficially known as a Series 2. This was the first appearance of the WFE trademark and emblem... and a red stripe on the tractor. Now, it can be tough to tell because sheet metal may not be original on a tractor what year it is unless you have a serial number guide. The silver stripes had on the side panel "WHITE", whereas in 1981 model year and later, "WFE" appeared on the side with a red stripe. It is not uncommon to find that some silver stripe owners choose to re-decal their tractors with the red stripe decal, but retain the "WHITE" nameplate on the side panels. Hope this helps.
Shep Va
08-21-2003 07:23:51
My books all say that the series 3 (red stripe)White tractors started in 1982. It looks like they built Series 1 and series 3 tractors in 1982 so that should be the only year that you should see models of both.
