 If you do decide your pump needs a rebuild go to this link. However here is the trouble shooting text from the shop manual. Settling is caused by leakage from the cylinder, between the valve and cylinder or in the valve. When the cylinder and valve assembly is removed from the unit, remove the piston and fill the cylinder two-thirds full of oil. Insert the piston and connecting rod in the cylinder and place them in a press (see figure 10-15). The pilot valve spool must be in neutral, or slightly toward raise for this test. Apply 4 tons pressure on the piston with the press (this is equivalent to 1000 pounds per square inch of piston surface): 1. If oil comes out the end of the valve spool(point A Figure 10-16) at a rate of more than one drop per second, look for a worn valve spool or valve spool bore. 2. If oil come out of the hole marked B, then the ball check valve is leaking. Look for dirt between the ball and seat, or a damaged and worn seat. 3. If oil comes out from between the valve body and cylinder, lok for damaged or worn "O" rings. 4. If oil comes up around piston, look for worn "O" ring or scored cylinder wall. 5. Check for leakage around the pipe plug on the front end of the cylinder. Tractors prior to serial number 6 503-500 had a safety valve in this location; remove this valve and intall a 1/4 inch pipe plug.
