PB Blaster??
Nathan
08-19-2003 14:40:28
I have seen a few people mention something called "PB Blaster" in this forum. I am curious to know what this is and what it is used for?
D13
08-23-2003 05:55:35
 Re: PB Blaster?? in reply to Nathan, 08-19-2003 14:40:28
I've used Kroil and PB Blaster. I get PB locally in nice aerosol cans, on sale for $2. Kroil is in larger cans or aerosols at $$$$.
PB works great, I use it on nuts bolts etc where I'm in a hurry, it's hard to reach, and I can replace the fastener if it breaks. In other words, day to day.
For really big and delicate stuff I use Kroil. It takes longer but seems to do better. If I can heat the part I get it warm and then apply Kroil. 2-3 rounds of this plus tapping and the job is almost always done. I use Kroil on things like frozen rings, where I can soak the part and cover it to keep wet. PB evaporates and leaves the wax behind pretty quickly.
Either beats WD-40. Note that WD stands for Water Displacing and not for Penetrating Oil! WD-40 will happily dechrome your shafts and rings while PB and Kroil won't.
RockinB
08-21-2003 05:39:12
Kroil is much better than Blaster
John Holcomb
08-20-2003 17:38:00
If you like PB Blaster than tryGM heat riser lubricant. You can only get it a a GM dealer but it is the best, beats blaster, kroil, gibbs works when nothing else will.
Nathan
08-20-2003 15:52:08
Thanks for all the quick responses!
Nathan
Super 55
08-20-2003 16:46:59
 Re: Re: PB Blaster?? in reply to Nathan, 08-20-2003 15:52:08
Funny you should post this today. I used some for the first time today and it worked great.
Mike (WA)
08-20-2003 12:20:57
How does it compare with Kroil?
Ollie
08-19-2003 18:41:59
PB Blaster is the best penetrant there is, period. Try it, you'll like it.
RB
08-19-2003 16:19:25
PB Blaster is a penetrating oil similar to Liquid Wrench. It works fairly well on rusty bolts, but you have to be patient with some of them. It won't loosen everything. Walmart stocks it, as well as most parts houses.
