Oliver 60 Overhaul parts
Trevor
08-18-2003 13:57:04
Well, I have told people that Oliver was not that popular in southern Ontario, now it has come around and bit me in the butt.
I have taken the head off my Oliver 60 to our usual rebuild machinist and he uasually overhauls the head (new valves, seats so on) and gets the rings and gaskets for us. Well he can't find all the parts we need. He can't find a set of new valves and can't get a complete gasket set, I am not sure he can even get the rings. Agco has been no help.
Where would you guys go to get these parts for an Oliver 60.
Thanks in advance.
Rick
08-19-2003 04:51:03
 Re: Oliver 60 Overhaul parts in reply to Trevor , 08-18-2003 13:57:04
US Funds Int. Valves are $ 20.00 exh. valves are $ 27.00. Most gaskets are available. Give me call TollFree 1-866-264-9720
Super 55
08-18-2003 22:26:24
Try Maibach's in Ohio. If you click on the link below you will find some info.
Click on the contact info to get their phone number.
Good luck. If they can't help you try O'Brien County at this link.
Link
Ron Grother
08-18-2003 16:20:33
you can ring and gaskets no problem www.dol./~dave.reed/otto hope this will help
ajax implement
08-20-2003 14:53:19
 Re: Re: Oliver 60 Overhaul parts in reply to Ron Grother, 08-18-2003 16:20:33
You guys scare me. I used a gasket set I got from Agco. I can also fix you up with a Perfect Circle ring set.
Geoffrey in KS
08-19-2003 19:05:19
Ron,
That address didn't work. Are you sure it's correct. I'm looking for overhaul parts too.
Thanks,
Geoffrey
Ron Grother
08-20-2003 15:37:01
 Re: Re: Re: Oliver 60 Overhaul parts in reply to Geoffrey in KS, 08-19-2003 19:05:19
try this : Otto Gas Engine Works PH.# 410-398-7340 What else do you need for parts ? I have four 60 Standards.
Trevor
08-22-2003 08:10:51
 Re: Re: Re: Re: Oliver 60 Overhaul parts in reply to Ron Grother, 08-20-2003 15:37:01
Ron,
Where are you located??? I bought a basket case and need quite a few parts.
Some of things I need.
Complete Seat Assembly
Air Cleaner
Front Rims
Lights and Brackets
Battery box
Front Hub cap
Other misc stuff.
Email me and we can see if we can make a deal and set up shipping to Canada.
Ron Grother
08-27-2003 15:53:53
 Re: Re: Re: Re: Re: Oliver 60 Overhaul parts in reply to Trevor, 08-22-2003 08:10:51
hear what I can help with rims 45.00 each air cleaner 25.00 light bracket 15.00 each lights 40.00 each front hub cap 15.00 there are repo. battery boxes. the seat I will have to get back to you. I will be going frederiction N.B in a week or so to bring one home then I can check the seat. I live in Maine
