super 55 electrical
Phil
08-18-2003 09:40:04
I have a 1956 super 55. The tractor still has the 6 volt system. I have the positive connected to the starter and the ground to ground, this has been this way for two years. Now my amp gauge does not show a charge even though the battery was very week when I started the tractor. Does this have any thing to do with the way I have the battery hooked up? Should I just change the cables on the battery?
When I charge the battery I hook the charger positive to positive on the battery, and it seems to charge although it never seems to charge completly.
Dennis(SoCal)
08-18-2003 12:28:30
 Re: super 55 electrical in reply to Phil, 08-18-2003 09:40:04
Your Super 55 should have been positive ground originally. Sounds like someone changed it to negative ground. The minus - side of your battery should have been connected to the starter and the + positive side to the frame of your tractor. You should be able to search in this site and find a wiring diagram for the Super 55.
phil
08-19-2003 04:58:51
 Re: Re: super 55 electrical in reply to Dennis(SoCal), 08-18-2003 12:28:30
Thanks all for the input. I guess my question is should I reverse the battery cables, and will this cause a problem with electrical system?
Mike B
08-20-2003 10:34:58
 Re: Re: Re: super 55 electrical in reply to phil, 08-19-2003 04:58:51
You can change the electrical system to a negative ground but you must also switch a few things. If there is no compelling reason to do so, I suggest that you leave it alone. If you do switch polarity, you must switch the leads on the coil (+ post on the coil to ignition if negative ground)and you must repolarize the generator so that it will charge the battery and not fry the regulator. This is quick and easy but I am a bit rusty at the process so please search the internet for tips on how to do it. Loss of polarity may be the principle cause of your battery not charging or it could also be a tired battery or a mis-adjusted regulator. The leads on the ammeter (if equipped) will also have to be reversed. The starter motor will work the same way regardless of the polarity.
Good luck.
ajax implement
08-20-2003 15:02:23
 Re: Re: Re: Re: super 55 electrical in reply to Mike B, 08-20-2003 10:34:58
Mike is correct. Polarize the regulator and I have to look too on how to do it anymore.Also polish the commutator with fine grit sand paper and either buy or borrow a volt meter and see what kind of voltage the generator is putting out. You can also ground the field terminal of the regulator and see if it charges. This takes the regulator out of the circuit.Also make sure your battery is fully charged before you do this.
Mike is also correct on how to hook up the coil. When you use the voltmeter also check how much voltage you have while the engine is cranking over as maybe you have a poor connection somewhere. 1957 and later Oliver gas tractors have 12 volt ignition.
jake
08-19-2003 06:18:27
If hooked up proprerly the pos rerminal is grounded, the neg goes to the starter. The coil pos to the ign switch and the neg to the points. The generator regulator will be attached to the gen with insulated grommets to prevent shorting.
Clint @ MD
08-18-2003 12:17:41
It sounds like Phil has his setup as a negative ground. "Positive to the starter, ground to the ground" as he says???
Positive ground should do just that. Go right to chassis ground. Thus your negative goes to the switch and then to the starter.
Negative ground has the negative side of the battery right to ground. Positive to the switch and then to starter.
Always charge positive to positive and negative to negative regardless of setup.
Have you had your battery tested lately??? Most places do it for free.
Bric
08-18-2003 10:01:17
All Super55 Gas were 6 volts positive ground so there is nothing wrong with your cables polarity.
I guess your generator is the source of your problems.
I converted my 1956 super 55 gas, to a 12 volts system and I would reccommend anyone to do so.
