Super 55 steering oil or grease
Phil
08-15-2003 19:15:51
I have a 1956 Super 55. The manual steering box has 140 gear oil in it. Their is a small leak around the steering arm. Is their any reason I can't shoot grease in on top of the oil in the steering box?
Super 55
08-16-2003 09:17:16
 Re: Super 55 steering oil or grease in reply to Phil, 08-15-2003 19:15:51
Larry from Maryland has it right. Here is what it says in the shop manual.
The first tractors built with Saginaw gears were filled with 90 gear lubricant. Continue using the 90 gear lubricant until such time as the stering gear is disassembled and cleaned. Then refill with No.1 multipurpose grease. Super 55 and 550 steering gears without the pipe plug on the front of the gear were originally filled with 90 gear lubricant. When the change was made to using No.1 multi-purpose grease, the plug was added to the front of the gear housing to facilitate filling the unit.
Larry from MD
08-16-2003 08:58:27
Yes use grease,the owners manuel says oil,but the service manuel say calceum or lithum grease.One of the bolt holes that holds the steering arms in is usualy drilled into the case so just insert your grease gun pipe and pump it in.After you let the oil out.
Thomas
08-18-2003 15:29:32
 Re: Re: Super 55 steering oil or grease in reply to Larry from MD, 08-16-2003 08:58:27
I was talking to a local dealer that is into haying eqipment and such mostly and he said they use a 00 Grease or sometheng like that in gear boxes on brush hogs when they start to leak and it prity much fixes it but he said this stuf still flows like oil would that work in the stering box too Thank you Thomas
Larry from MD
08-18-2003 17:02:20
 Re: Re: Re: Super 55 steering oil or grease in reply to Thomas, 08-18-2003 15:29:32
It should work fine as long as the seals are still halfway ok.My favorite is Deere corn head grease,it flows some and stays in great,and its made to work in gearboxes.
Thomas
08-20-2003 13:04:05
 Re: Re: Re: Re: Super 55 steering oil or grease in reply to Larry from MD, 08-18-2003 17:02:20
Thanks I will be puting that in one of these days
corn head grease was the other name he had for it I did not remember that untel I was at the Deere dealer and talked to them about it and the tube said 0 Grease on it Thanks Thomas
