Cockshutt 40 3pt hitch
Kevin
08-12-2003 07:08:33
I just purchased a Cockshutt 40 and I want to use it around my farm. I would like to add a 3 pt hitch assembly so I can run a tiller or circular mower. Does anyone know if they made a 3 pt hitch or if there are plans to build one?
Kevin
Frank
08-12-2003 19:38:35
 Re: Cockshutt 40 3pt hitch in reply to Kevin, 08-12-2003 07:08:33
I've been trying to find one for mine for a while now. The good new is you can use the parts from a 35 40 50 560 and 570 they are all they same, or similar enough to work. The bad news is they aren�t much easier to find.
Nothing available as an after market system.
I'm attempting to build one for mine with a rockshaft from an AC D17 need to bush it up to the 2.125 size for the cockshutt, but the length is good. I made the lower arm mounting assy and the rest can just be after market parts.
Good luck
Frank
Unimog
08-12-2003 07:20:56
The 3pt was an option on the 40. It is quite rare
to find one on a tractor and finding a used 3pt
I would think even harder. I don't know of any
aftermarket company that makes a 3pt for the 40
as they were a low production tractor(about 15000)
Costs would be high per unit.
