Hey Shep VA---Cummins ??
Myron KY
08-05-2003 13:14:13
Would a 5.9 Cummins that's been running a Berkley High Pressure Pump, be suitable has a re-power motor and is $2000 too high?
Just curious.
Myron KY
Mike D.
08-06-2003 11:08:12
 Re: Hey Shep VA---Cummins ?? in reply to Myron KY, 08-05-2003 13:14:13
Hello Myron, Long time. Did you loose the Perkins in your 1850? Or are you looking at doing a refit with another Oliver?
Myron KY
08-06-2003 12:16:20
 Re: Re: Hey Shep VA---Cummins ?? in reply to Mike D., 08-06-2003 11:08:12
Hey Mike,
Neither really. The 1850 is running good and I don't have another Oliver,,,,, ,,,,, yet. I was just curious and thought someone needing to re-power might be interested.
Did you get your water pump/vibration damper problem fixed?
Mike D.
08-06-2003 14:04:57
 Re: Re: Re: Hey Shep VA---Cummins ?? in reply to Myron KY, 08-06-2003 12:16:20
Egg on my face, some. Have not worked on it yet. I will though. The fan is wobbly and I fear it will cut loose and make a mess of the radiator. Don't use it much right now.
Shep Va
08-06-2003 05:38:05
Yeah, I would think that would work. I would try to find out what HP they are and if they have a turbo, Im bettin they dont, and get the hours on the engine, it may have high hours being a pump motor. The other thing is it could be a higher HP engine but have a lot of hours on it. Remember these Cummins engines should go 10,000 + hours before you need to even look at them, and they are real easy to rebuild.
I bought a 5.9L with 2000 hrs on it and no turbo for about $3,000, so Im betting that is about what that engine is. Probably work really good in a small tractor like a 1650 or 1655. Sounds pretty decent, I would check into it.
Myron KY
08-06-2003 06:39:21
 Re: Re: Hey Shep VA---Cummins ?? in reply to Shep Va, 08-06-2003 05:38:05
Thanks Shep. I saw some prices that 310 blocks and cranks are bringing and thought a $2000 Cummins was pretty cheap in comparison.
Got any hay baled yet?
Shep Va
08-06-2003 12:01:25
 Re: Re: Re: Hey Shep VA---Cummins ?? in reply to Myron KY, 08-06-2003 06:39:21
Yeah, that does sound a little cheap for a 5.9L Cummins, I bet if you check into it that they have a lot of hours or are in need of an overhaul.
Hay is still on the stand still for now, the weather has gotten into a pattern of thunderstorming every evening now for over a week. Hard to get hay dry like that. Plus I have my 1850 in the shop learning about hydraulic valves and interlocks in the remote system. Turns out I had a bunch of bad o-rings in my interlock valves for my remotes and it has been causing me problems. Im learning a lot more about hydraulics than I really ever wanted to know but I hope it will be finished up tonight.
Hows the weather been down your way???
Myron KY
08-06-2003 13:17:13
 Re: Re: Re: Re: Hey Shep VA---Cummins ?? in reply to Shep Va, 08-06-2003 12:01:25
Yeah probably high hours and poor maintenance.
Sorry to hear about the hydraulic troubles. Glad to hear your now a expert. I'll know who to call. :^)
About the same weather here. At least it's cooler than normal.
Thanks again for your input.
Super 55
08-05-2003 22:37:28
hey did you see how much those repower kits were on Fastline....?
Myron KY
08-06-2003 05:31:32
 Re: Re: Hey Shep VA---Cummins ?? in reply to Super 55, 08-05-2003 22:37:28
Sure did Super 55. I'm not sure if that price is reasonable or not. Maybe if the Cummins is new. They aren't far from me, as the crow flies, and I would like to go up and look at their conversions and see what all the kit contains.
I see that your making progress on your 55. You've got a nice web site started too. Keep up the good work.
Myron KY
Shep Va
08-06-2003 05:43:54
 Re: Re: Re: Hey Shep VA---Cummins ?? in reply to Myron KY, 08-06-2003 05:31:32
Really that is probably not a bad price for a new engine with a turbo, and all the "correct" parts to do a conversion. If you repower an Oliver with a new engine and all the right parts like that and pay the labor for someone to do it, it will cost about $10,000 to do a repower, so add labor to that price and you are there. The new engines themselves will cost about $7,000 with a turbo.
My repowers have not cost me that much though, because I use engines that have some hours on them, and I fabricate a lot of my parts that would normally cost a bunch. I have normally spent between $6,000 to $8,000 to put a repower in and that is with painting the tractor and the chrome pipes and a lot of other goodies that you wouldnt normally get at a shop. These Cummins engines last forever so I dont worry about a few hours on them.
MikeO
08-05-2003 17:07:11
Myron, is the Berkely pump still available? I am looking for one.
Myron KY
08-05-2003 18:57:52
 Re: Re: Hey Shep VA---Cummins ?? in reply to MikeO, 08-05-2003 17:07:11
As far as I know. They are tring to sell 2 pumps with motors for $5500 each. Motor alone is $2000. I saw the add in Fastline. Here's the link to it.
Regards,
Myron KY
