Super 55 Lever?
Kent Dacke
08-04-2003 13:32:59
Long time reader. First time writer. I have just purchaced an Oliver Super 55 with loader and power steering from a fellow that only buys and sells tractors. I have several questions.
1. Explain how to utilize all of the gears in the 6- speed transmission. 2. What is the stick shift lever beside the right side of the seat used for? It has a bumper perch mounted on the axle housing and a finger operated lever to engage a tab to lock the lever in two positions. It looks as though it would disengage the clutch if the tractor were to set for a long period of time. This theory failed when used as practicality or something is broke inside of the clutch housing.
The transmission would not engage without grinding.
Larry from MD
08-04-2003 15:41:52
 Re: Super 55 Lever? in reply to Kent Dacke, 08-04-2003 13:32:59
The lever is the pto clutch lever.The trans is a double H pattern,you can slip between the 2 H's in the center pushing the lever back or forward.
