88 diesel rough running at high rpms in idle
Tim
08-01-2003 20:50:49
this is my first "big" tractor and it seems to run rough and miss at high rpms in idle. Also it is hard to start when it is hot.
ajax implement
08-02-2003 17:07:04
 Re: 88 diesel rough running at high rpms in idle in reply to Tim, 08-01-2003 20:50:49
O. K. Are you making a statement or are you looking for help? We need more to go on than this. First thing take off the exhaust manifold and just slide it up. See if one cylinder misses or if the miss moves to different cylinders or what happens. How does it start cold? Does it have white smoke when it is cold and trying to start? Does it have white smoke starting when it has been worked for an hour?
Tim
08-02-2003 19:37:19
 Re: Re: 88 diesel rough running at high rpms in id in reply to ajax implement, 08-02-2003 17:07:04
It has white smoke when started cold. It runs great when it is in gear and no white smoke at all. It starts with either only. I am looking for help in diognosis. thanks
Don-WI
08-03-2003 20:20:04
 Re: Re: Re: 88 diesel rough running at high rpms i in reply to Tim, 08-02-2003 19:37:19
Sounds like you just need a rebuild, and either in an engine is just a slow form of murder(or FAST in some and most) If it needs either in this warm weather, it is in need of some major TLC. Maybe could be bad compression and just new rings could work, maybe a little to do with fuel system. Good luck whatever it is.
Donovan from Wisconsin
