Oliver 88 pull a 9ft haybine
John in IN
07-30-2003 21:06:19
Will a Oliver 88 diesel have enough power to pull a 489 New Holland Haybine?
Steve
08-01-2003 19:05:59
 Re: Oliver 88 pull a 9ft haybine in reply to John in IN, 07-30-2003 21:06:19
I've pulled one for years with a 77. You'll have no problem.
John in IN
08-03-2003 18:09:17
 Re: Re: Oliver 88 pull a 9ft haybine in reply to Steve, 08-01-2003 19:05:59
Thanks guys. I am going to try it.
INCase
07-31-2003 05:29:42
Is it the sickle bar type or disk type? If not a disk type it should have enought HP. A little 444 IH (30-35hp) can handle a 7ft unit nicely so a 88D should handle a 9ft. If it is a disk type you'll want at least 70hp twisting its tail.
