Need Help Cockshutt 40
Jerry
07-30-2003 15:19:41
I just bought a cockshutt 40 that has a bad engine. As I remove parts the color of many appear to reveal that the tractor was built as a co-op 40. Beside the bolts that retain the rear motor mounts is a pin with a c-clip on it. On my 30 it is a locator but I don't remember how to remove it. Can anyone help with information?
Irv
07-30-2003 17:40:41
 Re: Need Help Cockshutt 40 in reply to Jerry, 07-30-2003 15:19:41
Soke with PB or pennetraiting oil. some times with good small pry bar hook edge and pry up. if not and there is enough stiking up to get a hold with good vise grips you can work them out. Lastly you can use a bar to pick up rear of motor very carfully and work it up and down till pin gets up enough with motor setting in proper position that one of above options work. No matter what you do be gental as if you break ear off it will be hard and pricey to get a replacement. good luck Irv
Jerry
07-30-2003 18:13:50
 Re: Re: Need Help Cockshutt 40 in reply to Irv, 07-30-2003 17:40:41
Thanks Irv: I thought that it was like you discribed but it always helps to ask an expert. Jerry
Irv
07-31-2003 18:17:59
 Re: Re: Re: Need Help Cockshutt 40 in reply to Jerry, 07-30-2003 18:13:50
Jerry, an expert is some one who has their selves fooled into thinking they know it all! I am not convinced and don't claim to know it all. I have just learned the hard way and usually it's the expensive way, usually because I don't ask! Irv
Jerry
07-31-2003 15:03:50
One side came out today but the other side had to be drilled. The motor comes out tomarrow.
