More confusing information (which may not be necessary). The Coil. If it were 6 volts then a 6 volt coil would be fitted.Period. AS it's 12 volts, there are two alternatives really.
One is basically a '6 volt' or 'ballast resistor coil' with a ballast resistor in the circuit. The ballast resistor is to soak up, say, 6 volts (or there abouts) so there is (about)6 to 8 volts on the coil and 6 volts on the resistor when running. So they will be in series connection. When starting (and battery volts are being pulled down by the starter) the ballast resistor is short circuited (bypassed) so the full battery voltage goes across the coil and you get a better starting spark. As soon as the starter stops, the short circuit is broken and it reverts to feeding via the resistor. The other option is a simple 12 volt coil with no ballast resistor and this one is designed to take the full 12 volts all the time and give a good enough spark at start up. Modern spark ignition engines (before latest electronic systems) nearly always went for the ballast resistor type, due to smaller & cheaper battery, smaller & cheaper starter (slower cranking?) and longer life, cheaper coil (doesn't have to be built for extra starting energy). So that is why a ballast resistor coil with no resistor is bad news. It will draw about twice the current (gives a super spark for starting), but inevitably will overheat itself and also burn the points (due to the high current at closure and high energy sparking at opening). Follow coil supply wire back and see if it has two connections, one fed from the ignition switch, via the resistor, and one from the starter relay feed, to after the resistor. A single feed from the ignition switch will generally indicate a simple 12 volt coil. Alternatively, disconnect the power lead at the starter, and then check the volts, across the coil supply and earth, with the key in 'run' position and then 'start' position, making sure the points are closed for the test. No change means simple coil; higher reading on 'start' position indicates there is a ballast resistor fitted. Hope this helps. Regards, RAB
