Cockshutt 40 with 3pt
Terry Danson
07-27-2003 19:28:45
I just bought a Cockshutt 40 with an adjustable wide front end and a three point hitch. How common is the three point? I've never seen one and i'm wondering if i've found somthing rare? Any help would be appreciated.
Irv
07-28-2003 04:16:17
 Re: Cockshutt 40 with 3pt in reply to Terry Danson, 07-27-2003 19:28:45
They are not really rare but hard to find complete original for the person who wants one with out paying more then they are worth! Alot of people who have no paticular use for them will take all but hydraulic box off and put it away to lighten tractor or just to get it out of the way. I have several tractors with them on and use them regularly. Irv
Frank
07-27-2003 19:53:02
The 3pt for the 40 is the same as the 35 and 50 not really common, but not all that rare. Do you have the floating 3pt or the fixed version?
Terry Danson
07-28-2003 04:43:57
 Re: Re: Cockshutt 40 with 3pt in reply to Frank, 07-27-2003 19:53:02
How can i tell if i have the fixed or floating three point? what do you mean by floating?
Irv
07-28-2003 16:40:10
 Re: Re: Re: Cockshutt 40 with 3pt in reply to Terry Danson, 07-28-2003 04:43:57
The fixed type rock shaft as we are calling it was mostly designed for mounted cultivaters. It can be used as 3 point if you have those arms and not the cultivater brackets. The other rockshaft uses a pin and 2 holes to alow you to lock shaft in for downward and fixed pressure the other hole is for floating possition! Irv
Frank
07-28-2003 07:03:53
The fixed version has the arm for the hydraulic cylinder welded to the rockshaft. On the floating version the arm for the cylinder is free and it has an extra bracket and a pin that allows you to have rockshaft fixed to the arm or floating (able to float up if the implement rises). The floating version came along around the same time as the 35 I think, so it would be used on 1956 and later model 40s. The floating version is a vast improvement over the fixed one if you want to use it for back blading, but ether one is a useful addition to any of the round nose tractors. Enjoy your new Cockshutt and don�t hesitate to ask questions. There are a lot of good people here with a wealth of useful information.
