66 Rowcrop oil filter damage
Cam
07-27-2003 18:57:34
I have an Oliver 66 Row crop gas. The metal at the base of the oil filter expanded due to pressure and began to leak. I changed the oil and put on a new Fram C253 oil filter. It blew the new oil filter base out as well which caused it to leak oil again around the rubber oil filter gasket. I seem to to 70 psi on the oil pressure guage on the dash. Wondering, what's the problem?
Cam
07-28-2003 18:42:17
 Re: 66 Rowcrop oil filter damage in reply to Cam, 07-27-2003 18:57:34
Larry, Jake and Sos puller. Thanks for taking time to help.
Sincere thanks.
Cam
Larry from MD
07-28-2003 09:04:13
There is a good chance the restrictor in the base of the oil filter has come out and got stuck in the return hole this causes high oil preasure in the filter.The tube above the restrictor is most likely gone and will need to be replaced too.
jake
07-28-2003 04:12:16
If you are running 70psi it's a wonder the main seals haven't blown, should have 20psi. As sos puller said check the relief valve, I keep a spare oil pressure gauge with a 6" line to double check the dash mounted one. LOL
sos puller
07-27-2003 22:23:47
there is a oil relief valve front right hand corner of the motor its a hex head bolt with a spring inside could be stuck or dirty hope this helps
