looking for info on Oliver 1950T
Jonathan
07-27-2003 09:29:54
Hello, I was wondering if an Oliver 1950 with factory turbo diesel is rare?. Also, The one I'm looking at has big fuel tank fenders, I'm wondering if those were optional or came as standard equipment?. How many horse power does this tractor have?.
thanks in advance!
ajax implement
07-27-2003 09:49:05
 Re: looking for info on Oliver 1950T in reply to Jonathan, 07-27-2003 09:29:54
A couple of things that might make the tractor a little on the rare side. Does it only have one air cleaner, Only the last run had the single air cleaner? Does it have a hydra-power or an over undershift? They were on the market before the over-under was available but only part of the first years production. Does it have front wheel assist or a Cat-3 three point? About 110 Horsepower. They run good at that. Fender tanks are almost required since the main tank is small. You also had the optional of a cab cab
Jonathan
07-27-2003 10:44:07
 Re: Re: looking for info on Oliver 1950T in reply to ajax implement, 07-27-2003 09:49:05
this one has hydra power and I think, two air cleaners. It does have 3pt, no cab, and it's 2wd.
Did it come from the factory with 110hp or is that figure achieved with adjustments to the fuel pump?.
WFE
07-29-2003 04:52:32
 Re: Re: Re: looking for info on Oliver 1950T in reply to Jonathan, 07-27-2003 10:44:07
Nebraska tractor test rated at 105hp pto, but most came from factory at around 110 or even stronger. Adjustments to fuel pump can get you up to 150 hp if you so desire, but you'll want to make sure the engine is fresh and properly rebuilt to take it. A nice Oliver to have in the stable...
