Oliver 60 -- electrical problem
randy
04-28-1999 04:27:52
i just put a new (actually rebuilt) 6-volt generator and a new cutout (acts like a voltage regulator, i think, but isn't one really) on my 60.
the ammeter dances back and forth between 20 amps discharge and 0 amps, real fast, like it was possessed. working correctly, it should register 4-10 amps positive.
i polarized the relay before running the tractor. i have double checked all the wiring and it is all connected correctly according to the drawings in my owners manual.
so what am i doing wrong, or what else needs checking??
David Davis
04-28-1999 12:10:10
 Re: oliver 60 -- electrical problem in reply to randy, 04-28-1999 04:27:52
Check cutout wiring,did you wire for positive ground or negitive ground.If reversed it will at as you described. Dave
