Key position, light switch, and Missing Switch?
Biscuit
07-24-2003 09:36:34
It has been a very long time 20 years since I have operated any tractor and never an Oliver so I don't feel too embarassed by asking this question. What are the three key positions? I know the middle or horizontal is off, the key is removable. Up to the right is ignition on, right? No idea what down to the left is.
Do I need to use the light switch to have the generator charge the battery? The lights don't work and the wires are all stripped so I figure it will cause a short to turn the switch on.
I have the key switch and the light switch but there is another hole where a switch used to be, what was it?
ajax implement
07-25-2003 19:31:30
 Re: Key position, light switch, and Missing Switch in reply to Biscuit, 07-24-2003 09:36:34
Most likely your missing switch is a hole about 1 inch in diameter with a little hole on each side like to attach it with two small bolts. if so that is where the switch for a preheater for a diesel goes.
Biscuit
07-26-2003 05:01:37
 Re: Re: Key position, light switch, and Missing Sw in reply to ajax implement, 07-25-2003 19:31:30
That is exactly what it looks like. Thank you very much.
Don-WI
07-24-2003 20:40:50
What model is it? These positions(up-right, down left) don't sound familiar to me. We own a 1600 and a 1755, and they have the same positions. turn to the left is acc, striaght up & down in off, right is ignition/ electrical systems on, turn all the way to the right starts the engine. I don't know of any other switch other than the lights and ign.
Donovan from Wisconsin
Biscuit
07-25-2003 05:27:56
 Re: Re: Key position, light switch, and Missing Sw in reply to Don-WI, 07-24-2003 20:40:50
Sorry about that it is a Super 55. It doesn't start with the key it has a mechanical foot pedal to activate the starter. The key is off at horizontal compared to your vertical so I will assume until I get the manual that left is Accessories for which there aren't any but lights, and right is ignition which is how I have been using it. Thanks for the info. The light switch is either on or off so I assume that it isn't a rheostat for charging.
RAB
07-24-2003 12:23:43
I think you need an operating manual.
Regards, RAB
Biscuit
07-24-2003 14:53:32
 Re: Re: Key position, light switch, and Missing Sw in reply to RAB, 07-24-2003 12:23:43
I ordered one, just looking for some quick info until it arrives. Thanks for your advice.
ajax implement
07-26-2003 14:16:01
 Re: Re: Re: Key position, light switch, and Missin in reply to Biscuit, 07-24-2003 14:53:32
Biscuit: Go to: wwwoliverhartparr.com/ leave the question about the oil filter. I will find you if you do that before sunday noon
